Hi,
This is my first dual motor VESC setup. I’m currently configuring the VESC and the motor sounds like it doesn’t want to spin or as if it’s having a hard time spinning. When I run the detection, motor spins fine, however when I try to setup the Remote and to calibrate it, that’s where the motor doesn’t want to spin. Are my settings incorrect for the battery?
Edit: Battery Current Max I had it set to 20-25 before and motors didn’t want to spin.
Setup: Battery: 5s1p 8000 Mah 30c (2) I have them wired in series Link to the battery
Motor: C6374 170 kv VESC: 4.12 FlipskySetup diagram is also attached.
