I have a very odd specific problem. I have two 6355 motors from buildkitboards. They come with sensor wires, but get this, one decided to come lose (my fault, I know😂). It ended getting caught under the wheel and was yanked out.
My thought is this, I put the sensored motor in hybrid mode, so that it helps get the board going, then as soon as it passes the erpm limit, both motors will run unsensored together.
FYI I have 2 VESCs connected by canbus. Is this a terrible idea? I miss smooth startups.
Maybe not the answer you’re looking for, but if you contact buildkitboards, he might be willing to send you new sensor wires or the pcb. It would be a good chance to learn how to fix motors. I’ve never done this before though so it might be a bit more complicated than that.
For some reason in the new vesc tool the sensors wouldn’t detect on one motor. Switched to FOC now however and it runs perfectly detecting both motors.
