I have a ‘Bisek’ board from China. The electronics were faulty (common for their boards).
So I have replaced with the VESC. However I have it all connected (although not gone into the BLDC tool yet) but when pressing the power button on the board with both Vesc’s plugged into the boards power, the blue light on the boards switch fires up then fades along with the light on 1 of the Vesc’s.
If I take the power off 1 of the Vecs’s then the Vesc with power is fine and the board stays on. Same thing with the other Vesc.
I’m only guessing, but is there some issue powering 2 Vesc’s with the 1 power supply that have not been ‘fiddled’ with yet in the BLDC tool? If so, what setting do I have to change.
- Note: The motors wires are not yet connected to the Vesc’s but I assume this wouldn’t be an issue.
