So I have been thinking about whether I get a specialised motor for Eboards, for example the Enetion 190KV electric skateboard motor 3655 or I just buy a stock high powered motor from the hobby store.
I read that The alternatives from the hobby shop are not designed with quality bearings suitable for carrying human size loads, they will often use leads that are inflexible & have tiny 4mm connectors that just can’t handle the high amps that can often be pulled into the motor when climbing steep hills. The Enertion R-SPEC motor has large open ports to maximise air-flow and minimize weight. The R-SPEC motors offer minimal drag when unpowered allowing the smoothest free ride out of any motor on the market. I was wondering if this is true and if having a specialised motor will be an advantage, personally I would like one of the best hobby motors without spending too much. Any help?
