Who will die first
Maybe all survive, but i dont think that this would be funny
Starting here a new tread with known and also new parts in different combination…
More then one reason for it
Looking for hard testing of the new Vesc-6
Also wanna really try to kill one of my drivegears… dont managed that until now
Got more then one request for 80mm Motors on Direct Drive, so checking for clearence btw
wanna use the 80mm Leopards agian, always loved this shiny red big bad MTF
So here we go with a slightly used Direct Drive (its one from the CNC machined Premium ones… but dont matters… in the end if it here fits we will be fine with the Laser Cutted ones too because they are little narrower…
Its Vesc6 Dude, we will screw the amps up to new Limits … hopefully
I think with 120a this things starts to breath heavily… on a continious level you will never extend that 80A limit IMO, only burst for short periods of time
Super interrested if we get it on a brutal Roxxy level with better control and all the nice Vesc features…
@benjammin
that guy drives me crazy … pissing my pants Dude
if the vesc6 really delivers 60 constant Amps that would be 2700Watt@12s so >50000Watt in Dual with 10 000Watt possible MaxAmp bursts.
And tons of torque from the Leo 8072 I guess thats more than enough, otherwise @Nowind will be Highway-Ready then.
I shortened the Shafts with a angle grinder, fresh cutter and one fast cut… easy
This is what needet to remove on the normal E-Toxx Direct Drive, about 33mm free shaft length… about 11mm on the Leo´s
The mount use see here is a prototyp, was testing if it make sense to machine some pockets for wheight reduction in the stainless mount… laying around and just use it for checking clearence now
I mount it on one of the full machined aluminium ones, here the clearence to the Baseplate is about 7mm per side smaller then on the regular Direct Drive… will now mount the stuff for max tilt clearence check
Got lucky there dude… couldn’t have designed it tighter if you tried! How does the clearance look out the back of the board. Do the motors protrude past the rear tires, or are they just inside too?
the motors probably stick past it. on my drive setup with 6374’s the motors just barely clear. about 3-5mm inside 8" street tires. those beasts are way bigger. cant wait for the video jens:smiling_imp:
