I couldn’t get my enertion pulley of my motor, so I destroyed it to get it off. Needed get it off because i needed to weld my motor mount to truck. Mount was handmade and my trucks got terrible shape to fit it good on. So If i reorder from enertion just one pulley + shipping it will be 79$, OMG!!! So i find on ebay
Is it will be good or i’m totally f**ked? i have 12mm belt, but pulley is 16mm, also enertion one is from steel, but this made from aluminum. Does it change something, i mean size for my case and material it’s made of?
Is your wheel pulley 12mm? If it is and also has flanges you will probably be ok. If it doesn’t and you dont get your mount perfectly straight your belt will travel off of the wheel pulley.
Should be fine, I have used these before with same caveats as noted above i.e. Steel over soft aluminum but ok, 12mm to 12mm true mount, no keyway so file motor shaft for grubs and loctite A-OK
Since my motor don’t have keyway, I’ll be using just set screws. Will it hold? Also how do you take them off your motor when needed, when you have it hammered down with keyway?
Yeah, i have it! That was the reason to not get off my pulley, it was holding with one 3mm set screw. So when i tried to open with allen key, it was impossible, even with heat. So head of allen key as well as set screw was broken. So tried to drill it out, even then i couldn’t get it off, so last thing i took flex tool. And my loved enertion pulley was gone. Now i need to spend 79$ if want new one! Aluminum will be o.k. for some time, i believe that i’ll need to change them every 250 km or so, because it’s soft material. Also issue is that it’s 16mm, my belt and wheel pulley is 12mm, so belt will be traveling sideways:(
The grub screws that came with my ebay pulleys were short. They work but I wanted it to catch more threads. I used way longer screws plus loctite, zero problems till today.
