I wanted to know peoples experience with eboosted enclosures.
I’m pretty disappointed because I spent almost $200 on a JetSpud DS enclosure from Eboosted’s site, and it didn’t even fit the board or double stacked cells as advertised :/.
Basically the first two photos show that the enclosure is too long, and the last photo shows my double stacked battery pack and how shallow the enclosure is compared to the depth of the battery.
I’m using a single stack enclosure and it fits alright. The edge of the enclosure is dead close to the truck baseplate or riser, and that’s how it should be. Perhaps you should drop him a PM and see what he can do to help.
@Baswoods the enclosure has been designed to use the longer wheelbase holes, as you know the spud has a pretty short wheelbase and every milimiter counts to fit a bigger battery and electronics, that’s why I took this decision.
I see you used the inner position base plate holes for shorter wheel base and sealed the outter holes with car paint filler.
Is that a 2nd hand board because that sure looks like filler in those holes? These enclosures have been used time and time again and have proven to be perfect.
If you say so than ok.
But why the enclosure fit to the encarves for the wheels like it’s made for it?
Don’t get me wrong but @Eboosted usually use one template for every version of deck.
So they all the same size and they fit other guys decks which have the same as you…
And if the enclosure is made to fit a specific wheel base that information should be in the description for when someone is purchasing the product.
There’s no we’re in here that states that there’s a specific wheel base it was made for so I suggest it be adding in for future reference instead of suggesting that people remove nonexistent filler.
