Economical Build for Large Rider
i forgot to mention pulleys. No offense to Enertion, but i’m not a fan of the 3d printed wheel pulley. Especially not for bigger riders like you and I. Too much torque and faster wear. I had one printed in the strongest Nylon on Shapeways about a year ago. I have it on my GF’s board and even when tensioned as tight as i’m comfortable - it will still click on hard braking in particular. That means skipping.
Now maybe he’s using a new uber material, and perhaps some more aggressive teeth profile to grab the belt? The 12mm (vs mine at 9mm) absolutely will help! BUT at the end of the day it’s going to wear faster with us bigger guys. I would spend a few $ more and get one in aluminum or steel. I really like the older kits he had with the nice anodized blue aluminum wheel gears - but doesn’t look like it’s offered any longer. bummer. My current favorite is the DIYes one which is aluminum and also hollowed out under the gear/teeth which gives a smidge more clearance around the axle of the truck. Minor feature and not sure if he still has these…
And again 15mm wide belt and gears for a single setup - more contact area will help when properly tensioned to keep it from skipping when braking hard. Dual 9mm has been fine for me in the past, but if i can fit 12 or 15mm i might do that just to have more contact area.
GL!
It’s not 3D printed…3D printed pulleys break…
It’s some fiber glass reenforced stuff… Hard as rock
Thanks @Michaelinvegas! That is good to know because they aren’t cheap. I’d still prefer aluminum over plastic (even glass reinforced), but that’s just me.
A few of us are on the hunt for the older Enertion pulleys
I ordered two the other day…should be here by Friday …that was super fast…(thanks @onloop)
Yeah the pulleys you can’t break with normal use…now if you hit the corner of the curb…that would mess up an aluminum pulley too
I just say no to 3D print when it comes to moving parts and the board … It will just rattle that shit to pieces
so do you think a dual drvie 12mm setup would be fine with a 190 km motor and 10s with vesc
using enertions pulley belt kit??
Bingo !
You’ll be ripping in no time
You won’t be able to fit a dual 12mm pulley setup (at least as a dual rear).
i was planning on doing it diagonally
Perfect!
20 20 words
I’m actually gonna do a dual rear with one of the mounts reversed.
