the calculator is saying my top speed should be 28.16 mph weighted.
Now I just took my new build out for a test run and the ESC Monitor App is saying I hit 28.5 mph and I wasn’t really pushing the board which felt like it had a whole lot more left in it.
I am wondering how closely the calc is to real world performance? Or possibly the ESC monitor App isn’t accurate?
Your top speed is is most dependent on your motors kv. So if you easily reached 28 mph then it could be that there is the end. Of course downhill is a little more possible but if you change your gearing you would reach 35 mph easily.
The motor can only produce power when it is feed with a higher voltage than the motor is already running with. If that voltage is already reached then it can’t produce any more and vice versa can’t go faster.
Yea calculator said my set up with 16/60 pullies on 6 shooters top speed is 32mph but my GPS said I topped out at 37mph and got over 30 regularly. It’s a bit off for me too
@Battosaii thanks for the info. it’s good to know I am not the only one.
From my testing today I think this board could easily do 35 mph, I was deliberately taking it easy as it was the first proper test run and I wanted to limit the speed in case of failure.
Another factor would be BLDC vs FOC. I usually bring the efficiency down to 80 - 85% for FOC, as you loose a little top end. The calculator listed in the first post seems to be pretty accurate with my current set-up.
