Been lurking around this forum for a while now and noticed that there aren’t any bell/horn options I would consider viable for electric skateboards.
I had an idea of adding an electric bell on the the remote itself. This way you could, with a click of a button, notify pedestrians that you are coming.
Rockbros bell was posted on a thread that discussed bell in general. I noticed it uses two coin batteries which I assume give 3V voltage.
Regarding the remote I could only find Boosted board remote battery information which was a 3,7V 450mAh battery. I won’t be using that exact remote, but for the examples sake lets use these specifications.
So I have three questions:
Is this a totally crazy/stupid idea?
Is this diagram I made right? (resistor and voltage wise)
Could the remote battery be replaced with a bigger battery for example this one?
Now I understand that the bell won’t fit into the remote even with the silicone striped of it, but I’m thinking of taking just the board, button and speaker from it. I would design and 3d print a new housing for the whole remote.
@Funkypumpkin Hi - we seem to on similar builds here on upgrading remotes with batteries and bells see my post mini remote upgrade
I am using identical bell to you - have you measured the bell current at 225mA as per diagram above ? . Seems a bit high to me but I don’t have my bell yet to measure current.
