Electric Dual HUB Motor Disassembly & Performance
Actually Jacob has a nice mounting method where it can go on any trucks. These have a special hanger necessary.
@evan Well there are advantages of belt driven compared to hub motor especially in regards of torque. However I still feel that belt driven system have too much parts to maintain. Cleaning is horrible when you ride in almost rainy weather every time. Nevertheless belt drive needs to be adjusted frequently to make sure that the belt are tight, aligned and screwed properly as they tend to vibrate alot.
Hub motor single speed should be the future of electric longboard. Its a complete elegant solution. Its cheaper than purchasing motor, mount, belt and pulleys. Making it possible to go for dual configuration in slightly more pricier category. But the torque, the setup feels better. I believe higher torque, belt drive system are nice for mountainboard drive. They require more torque and made for special purpose of climbing, jumping, etc. Since longboard are made purely to be ridden on normal street path, hub motor is ideal the way I look at it.
@Hummie Yes I know jacob and your hub motor build. They are awesome and still in production - development. One two small thing that I donā€™t envy on jacob hub motor is the mounting option on standard truck axle. They need to be twisted to lock into the axle and the hold by a grub screw. Locking into axle have consequences like jacob stated that these eboards have power to accelerate and decelerate. It means torsional load are applied clockwise and counter-clockwise. So during acceleration or deceleration it could undo the locking, thats why the grub screw are to lock it further. Itā€™s fine solution but somehow I have bad experience with twist lock mechanism to handle torsional load since I have ridden friction drive before. Also all hub motor are open designed and not sealed for heat exchange. The Netherlands is always misty and 80% of the days are cloudy and wet. I donā€™t cruise when it rains, but its unavoidable to go home completely wet.
Honestly if I have the ability to create my own hub motor, I would start from scratch. Starting from wheels, hub and axle. The specs would be
  1. Weather sealed but not heating up easily.
  2. Custom truck axle design is fine (buyer will need to buy the hub motor anyway, so the axle could be an all in one package too). As buyer I donā€™t mind getting a nice axle for hub motor config if they are mechanically excellent. Even if the truck axle is one piece with the stator axle, if they could align perfectly minimizing the wobble, iā€™ll be fine.
  3. It would be great to have varieties of different wheels replacement from color, size and durometer or even brand. That means the ā€œsellerā€ provide a lathed / cut branded wheels from Orangatang / abec 11 as wheel replacement. So we as longboarder could have the same wheels feeling as common longboard wheels.
Iā€™m curious what the wheel/motor bearings are sitting on. Are they simply sitting on the long threaded bolt? Bearings siting on threads isnā€™t good. And if itā€™s structurally as I imagineā€¦the weight of the rider is putting so much force on that lever, the bolt, and itā€™s not supported until it gets into the aluminum hanger. Strange because they have steel in the center of the stator, which is strong and good, but it doesnā€™t really matter because itā€™s not taking any loadā€¦ The best and only thing good about the steel center is itā€™s a solid shaft for the smaller outside bearing which is a weak point.
At first I thought maybe it was a robust design with the inner steel but nowā€¦ Maybe I have it wrong but is that long bolt, that the bearings are sitting on, spanning all the way through the motor and then it inserts into the aluminum threading? Thatā€™s a crazy long span and doubt the square peg will take much of the load.
Motors are almost waterproof as is. I wouldnā€™t worry about it especially if u seal the connections from the motor leads to the windings.
I thought Jacob changed from. The little grub screw to a nice locking mechanism,
@Hummie I think I might know what you are in doubt with they are not completely right, but the weak point still lies within the long bolt that hold the hub motor to the axle.
The stator axle is one solid steel axle with round edge on one side and dipped rectangular spot on the other side. They could be mounted on the truck axle without both hub motor cover installed. It will stay locked in that position. So the torsional load, are all being hold by this rectangular spot.
In short this rectangular insertion hold the hub motor axle in place. It holds the torsional load as well as making sure that the hub motor sit horizontally perfect to the truck axle. The long bolt will lock onto this black rounded side of the stator axle.
So the bearings inner side will sit on the outter side of this black rounded stator axle.
Just for clarity, this is the photo of the back side of the hub motor.
In the end the bolt has to hold the hub motor rectangular spot with the truck axle rectangular spot are always perfectly intact. So the whole load sits on that tiny rectangular spot, which is quite small and weak. Also the insertion of this long bolt to the truck axle is only about 1 cm (you can see it from the photo above the discoloration on the bolt), which is quite short while the bolt its self is 6cm long. So the bolt doesnt hold any torsional load at all!
This design could be perfected if the chinese manufacturer extend this small flat rectangular spot all the way through the hub motor stator axle. Ensuring that is perfectly perpendicular all the way from the edge of truck axle to the edge of the hub motor stator axle, spreading the torsional load and weight along the rectangular shaft.
the torsion load I wasnā€™t concerned about. and not catastrophic if it fails. Maybe strip the wires at worst but not have the wheel come off.
You say the bolt only goes into the aluminum hanger a cm? Scary.
The bearings do they sit on a shaft thatā€™s threaded? That has to be bad but not as scary as the 1cm threading of aluminum thatā€™s right at the fulcrum
If u want to get a set of the motors I had made to see how they compare Iā€™ll send them to you for the 200$ Plus shipping. Be nice to see how they compare.
Someoneā€¦the only person Iā€™ve heard ofā€¦is getting the NGV motors and was also getting mine but backed out of mine. Disapointing as Iā€™d like to have heard a comparison of those as well
Maybe theyā€™re all great.
Iā€™ve only done 150 miles with mine before they shorted through a simple insulation problem but I wonder how things will go at mile 50,000. Iā€™ll still be riding them if theyā€™re going and definately donā€™t want a wheel falling off.
Can u put a longer threaded shaft throught the hanger?
Bearings on threads thoughā€¦no one does that probably for a reason.
Yeap I know that belt drive is hard to go drop-through setup which I really want to. But hub motor canā€™t change truck/wheels easily because the design, maybe someday it might be change or something.
So at this moment the best way to us should be like having both setup and skating crazily everyday hahaha.
@evan To be honest changing the wheels are more important than trucks from my pov. Because the affect of trucks to the style of longboarder doesnā€™t change significantly compared to the wheels. Since elongboard are not meant to do tricks, from my pov it doesnt matter at all. In fact how many times do you think you change set of trucks compared to set of wheels. The amount of trucks out there are only a few, even then belt driven mount also currently only supporting paris and caliber 2 trucks.
@Hummie yes itā€™s scary! Thats why if you scroll back above, I do NOT recommend this hub motor for heavy duty and heavy load purpose as most of the stress are being hold by that small rectangular spot. Although they are NOT aluminum, they are steel for sure, from mechanical perspective they will for sure have to hold the entire stress we put.
The bearings doesnā€™t sit on the threaded shaft (the bolt). The stator axle has its on hollow shaft and the threaded shaft goes in it locking the stator axle to the truck. Anyway Iā€™d be happy to have your Hub motor to be compared side by side. But first let me get my VESC shipment from Chaka have this tested, if my budget fits for 2nd build I would definitely contact you.
Nevertheless Is there any photos where I could see how you mount the hub motor to the truck? I didnā€™t seem to see it / understand it properly from ES. For the rest of the build of the chinese hub motor compared to your build seems to be quite identical despite different size of bearings and how the cover are locked with the motor can.
i think thereā€™s a video where Jason talked about this hub motor . somewhere in his youtube vlog or instagram vids . fyi , theres alot of china e~skate hub motors popping up in alibaba & aliexpress . idk about amazon or ebay . maybe there is too . some even offer complete dual hub set up incl remote , 2 escs + programmer and 22V 18650 pack battery . at only USD$469 (i think)
same as you , i dont like the colour . darker blue is ok , since itā€™s touching the ground . cobalt blue like those wheels ? are not my taste . its a ā€œturn~offā€ colour .
@mostwanted Yea Jason talked about this hub motor within one of his youtube vlog. I already have this hub motor for sometime already about (1 - 2 months, beginning of this year). Iā€™ve been thinking to post this with my upgraded build later, but I changed my mind. It seems better to have it open in another post :smile:
As far as my investigation, there are only 2 suppliers I could found that sells electric hub motor for longboard. However I decided to go over Lofty Ambition as it seems to be more solid build (in my pov).
Iā€™ve been thinking for sometime now to have my wheels painted black, maybe dyed black. Not sure if that would work.
So the skate hanger is steel?
Doubt u could dye the wheel.
Yes they are steel, in fact they are all steel. There is no plastic involve in this hub motor besides the bearing cover. These hub motor are quite heavy in my opinion. I actually expect hub motor to be lighter and more powerful.
I wouldnā€™t have thought plastic but maybe an aluminum hanger. Steel hangerā€¦that is surely heavy. Thatā€™s a lot of steel
Yea I doubt theres anything aluminium here (besides the bearing, just like I was initially think).
Iā€™ve never heard of any aluminum in bearings. Maybe theyā€™d do the shields
Thereā€™s no way those hangers are made from steel. I can tell from looking at the threaded hole alone. Does a magnet stick to them ?
@trbt555 Yes I am wrong again :slight_smile: itā€™s from aluminium. However the rest are from steel (cover of the hub motor), they are attracted to magnets. The hanger is from aluminium. Strange aluminium are really expensive and if the Chinese is using it, I suppose the hanger are CNC machined. However when the bolt is attached without the hub motor, they doesnā€™t seems to aligned perfectly. Nevertheless I never expect I have aluminium hanger as all of my trucks are cast trucks.
Itā€™s probably cast aluminum and then they drill it after.
can u please show a picture of the bolt through the motor but not screwed into the hanger? You said there is a small amount of metal that is able to screw in. I think maybe most of the riderā€™s weight on the board would be on transfered through the threads and not the jigsaw piece sticking out of the motor.
Aluminum threads bearing the weight. Humm. Iā€™d fill the hanger with epoxy!
Here is the photo. From my pov, it appears that this rectangular spot hold most of the stress. The rest of the stress is from the bolt connection to the hanger hole in which its still the reactangular piece.
Also without the bolt attached, just placing the piece together I could stand on my board no problem.
Btw as you can see I painted the wheels and all of the things black. It occurs to me that the hub wheels are slightly too small or the fitting is too thight. It causes the hub wheel to slightly deformed and cause wobble on certain slow speed. I guess it would be fine after some run as the wheels will be grinded with the street, but still this shouldnt occur in the first place.
Wow, the all black stuff looks cool, did you use spraypaint or dye them in a different way? And have you tried them out unpowered already?
