I didn’t ordered Esc case/heatsink and it was a mistake… I planed to install both Esc on the sloped part of the aluminium bottom, above potential water entry, but it’s quite tight…will see.
Seems like current wheels wont go, at least would be interesting to see what do you come up with.
What’s your experience with these narrow wheels in general? Have u ridden such setup a lot?
I did for a while but cant say I was happy, the only up side was that these wheels are small and had lower power consumption versus bigger ones.
Otherwise on bad streets and sidewalk curbs they were rather hard and I think I could see wear on drive wheels quite soon, as usually after the ride the tires were considerably warm from the ride and whole contact with the road…
So yeh, I saw almost more downsides to them than plus sides. I guess these chinese 6inch ‘fat’ tires is a lot better option for riding.
Definetely should be a softer and more comfy ride using fatter wheels/tires.
Yes, I’m waiting for internal gears + spur gear (hopefully next week).
I’ve used these 7" wheels on the Flexboardz urban carver model. They have a lot of grip but needs to have the pressure accurately adjusted, hard enough to roll freely but not too much or it’s unconfortable…
The internal gear could almost fit inside for the hub of such tire
I plan to use these 7" wheels and/or 6,5" on this position (short wheelbase) and 8"/9" wheels on the other axle position (long wheel base), ideally while keeping the motor at the same position.
Mh ok, now I see u got 2 wheel positions available which is an interesting possibility.
Seems like your wheels are a bit bigger then, my wheels were 6 inch and 1.25’’ wide. Might be possible I ran them over inflated but non the less, there is little rubber and air in them, so not much suspension can be gained from them anyway.
The internal gear concept sounds good. How do u plan to acquire such internal gear ring?
Ive seen some 3d model designs but seeing one made from metal would be way different level. Though it seems that these plastic printed wheel gears are quite okay as long as motor gear/pinion is made from metal.
True, the 7" wheel are 2" wide…I’ve tried 6"x1.25" but it’s too narrow…so it’s either overinflated (too hard) or underinflated (too slow).
I’ll tell you where I get the internal gear if it doesn’t get destroyed after 5 mn of ride, otherwise, we will all forget about it and I won’t talk about oversized transmission…and yes, it has a steel motor gear.
Sadly, I don’t think that it can be used on truck as motor will interfere with hanger.
Then you enter into the “modulus, width, max torque” question…and compare to what is used on other gear transmission, it seems way undersized… so I prefer to test before to make any claim
Here are the different wheels I had at home before lockdown, 7" to 9" that can fit the board. I will have to get some 6" to cover the whole pneumies range
