Hello all, I am pretty new to this so please understand me.
First, I want to give out my current diagram and ask for recommendation according to what i wanted to build. Bear with my questions. I marked the picture with number that corresponds to my questions on this.
Main items used in my project
Here are the questions:
1) Should I re-build the T connectors into XT90 port to connect to the other modules easily?
OR If I were to keep it and make an extra T-Connector to XT90 converter to “less damage” the item, how should I make it according this connection of the ESC?
2) Battery Capacity Indicator: I am thinking this is placed in the right position. Should indicate when #3 switch is turned on.
3) BIGGEST concern. I plan to have two switches: One right after battery (Main ignition) and One on ESC (second ignition). First, Do I need anti-spark switch? I looked up a lot of anti-spark switches(vedder’s, etc), some parts were hard to find.
If then, what kind (value) of fuse, MOSFET, or other resistor/capacitor value do i need to use to secure this connection. I couldn’t find any math calculation you can use to find these factors according to my two 5000 mAh (in series) battery build.
4) Open circuit Port created right after battery connection for easy connection to the charger. Is this okay to connect to straight like that or do I need “charging switch” to secure the port? (please consider safety and all)
EXTRA question 5) I heard that 6S requires XT90. Using listed two 3S1P 5000mAH battery, do I need to use XT90 or can i use XT60?
Please do correct me if I am wrong. Please let me know guys. Help would be greatly appreciated! Thank you very much. Cheers!
