Electric Reaper | Never summer Reaper 2016 | TB218mm | Dual BKB 6374 190KV | Focbox
Been researching and planning on building an electric skateboard since beginning of last year. Original idea was I wanted something stealth with long range but I slowly got more and more carried away and ended up with this.
I wanted to try document parts and total cost as best I could to help highlight how quickly everything adds up and how expensive building a electric board can be with quality parts. So I have added almost everything I have purchased for this build not including the price of tools like a spot welder for making the battery or soldering iron.
Parts list
Item Cost QTY Shipping VAT Total
Deck Never Summer Reaper €219.00 1 - - €219.00
Front Truck Caliber II €34.95 1 - - €34.95
Rear Truck TorqueBoard 218mm €27.50 1 €17.50 €9.50 €54.50
Wheels 90mm Flywheel/clones (Blue) €36.00 1 €15.00 - €51.00
Total €349.95
VESC FocBox €145.00 2 €2.99 - €292.99
Motor BKB 6374 190KV €102.00 2 €30.00 €55.00 €289.00
Remote Nano-X €59.99 1 €2.99 - €62.98
Enclosure Eboosted Reaper €72.69 1 €27.25 - €99.94
Battery Samsung 30Q (10s4p) €3.80 40 €6.52 - €166.12
BMS Bestech 10S HCX-D223-V1 €60.00 1 €8.00 - €68.00
Power Switch Blue LED power switch €8.99 1 €2.99 - €11.98
Bluetooth module DIY HM10 module €3.00 1 - - €3.00
Charging port DC in 2.1mm socket €3.99 1 €2.99 - €6.98
18650 PCB Custom designed PCB €1.78 10 €1.99 - €20.89
Charger 42v 2a Lavolta. Cheap temporary charger €18.00 1 - - €18.00
Drivetrain Total €1039.88
Motor Mount marcmt88 Motor mount with dual idlers €42.00 2 €20.53 - €104.53
Wheel Pulley Enertion 12mm 36T injection molded (EU Groupbuy) €11.00 2 €7.00 - €29.00
Motor Pulley Custom HTD 5m 12mm 15 tooth €10.00 2 €2.99 - €22.99
Belt 12mm HTD 5M 305mm €8.00 2 €4.00 - €20.00
Total €176.52
Wire 12AWG Red silicone wire - 6 meter €9.01 1 - - €9.01
Wire 12AWG Black silicone wire - 6 meter €9.01 1 - - €9.01
Wire 14AWG Black silicone wire - 6 meter €5.80 1 - - €9.01
Wire Flat tinned braided copper - 2 meter €25.43 1 - - €25.43
Wire 12mm .15 pure nickle strip - 2 meter €9.00 1 €6.57 - €15.57
Wire Balance wire (ribbon cable) - 3 meter €6.99 1 - - €6.99
Connector XT-60 - 5 pairs €4.21 1 - - €4.21
Connector 3.5mm bullet connector - 10 pairs €1.75 1 - - €1.75
Connector 6mm bullet connector - 10 pairs €5.26 1 - - €5.26
Cable Management 100mm Heatshrink - 5 meter €10.15 1 €3.38 - €13.53
Cable Management 530 peice heatshrink kit €6.98 1 - - €6.98
Cable Management 8mm wire mesh guard - 2 meter €1.34 1 - - €1.34
Enclosure Mounting M4 threaded wood inserts - 10 pack €2.47 1 €3.93 - €6.40
Enclosure Mounting M4 20mm button head screws - 10 pack €0.80 1 - - €0.80
Enclosure Mounting M4 Rubber washers - 20 pack €2.54 1 €4.49 - €7.03
Misc Thread lock 242 €1.02 1 - - €1.02
Misc Thread lock 609 €0.84 1 - - €0.84
Misc Silver solder €9.66 1 - - €9.66
Misc Soft black gasket for enclosure - 2m €7.98 1 €2.99 - €10.97
Misc 3M hook and loop self adhesive tape - 3meter €11.99 1 - - €11.99
Total €156.80
Grand Total €1723.15
I have only just gotten everything togethe and not even taken it for a ride and already wanting to change things.
I got distracted from my original idea of a stealth board that is almost indistinguishable from a regular longboard, So have already purchased some Carvon V4 speeddrives to replace the whole back end with.
Guess not …
And want to replace the deck with a Hyper Beast deck by @NAF, or any kind of similar style sealed bottom deck for a more regular longboard look if I can find any.
Still have a small details to finish. I did want to channel the deck and run the motor wires through, but now that I want a new deck and carvons/quality hub motors I’m waiting before I do too much more work in case I change it all.
I loved my never summer Reaper, such a beautiful deck.
Hi do you know someone who sells enertion Wheel pulley 12mm ?
If you get a new deck, do you plan on selling the never summer reaper? Or keeping it? If so I be gladly willing to purchase it
