Well if I end up in this situation again I’ll give the heating route another go. I did try heating the pulley by holding a lighter under it for several minutes and I got a small amount of smoking which was when I could start rocking the pulley back and forth again but that’s as far as I got.
This is what the pulley was looking like before I gave up for the night last night. Except for a few mm’s at the back of the pulley where I can’t get my Dremel to cut without also cutting into the motor mount, I’ve cut right down to the motor shaft and the damn thing still won’t come off, even after using CRC, flat head screw drivers, more heat and whatever else I could find in my toolbox. Most stubborn piece of metal I’ve ever had to deal with
Think it’s going to be round 2 with the Dremel tonight. The plan now is to do a similar cut down the other side of the pulley which will hopefully allow me to split the damn thing in half…
