Unparalleled Performance & Hassle-free installation was our design objective!
This is the same Drive-train assembly Enertion is using for Raptor 2.1 builds, the Enertion R-SPEC DRIVE KIT comes fully assembled, as pictured below. The NEW motors have a 15mm steel axle & the motor/hanger assembly has integrated copper heat pipes to help extract heat directly from the core of the motor into the oversized aluminum hanger. The Hanger is 7075-T6 CNC billet aluminum with heat fins machined onto the majority of the surface to improve heat dissipation. These new cooling features result in 8% more torque during hill climbing. The motors also have built-in thermal sensors, when paired with a FOCBOX unity, you can create your own custom throttling profile to maximize performance without risk of damaging the motors when you are pushing maximum current.
Having 500 euros on hold from enertion because they take forever to ship.
On the other hand I want these badly even tho I don’t need them and have humies in the mail
Happened last year…
I expect the drive kit to take a little bit of time not as long as the focbox last year because the price is higher so some people won’t want to spend that on the drive. The focbox was so cheap that everyone could get it.
