Then I assume they should be outrunners. Just hard to speculate from the pics, as I have not seen a video of them in action.
Someone should check their kv… and tell whenever they are really 145kv to be that slow…or the esc or whatever part is just too weak to push someone more than 30kph with 10s battery…
There inrunner motors the gap between each screw is 37mm but the motors are 55 by 74 and the battery is a sealed blue unit with 37v 8.8ah written on it so would i be able to connect more to it there isnt much space!!.
So if i buy a wheel pulley with less teeth and a motor pulley with more would this work and get new belts?? say 20/36 or 18/36 where could i buy these from?
Or is their a better option? becuase it has a 16/60 3:75:1 ratio at the momment.
I dont have much time now… but theres a possibility that perhaps not enough amps are available (battery part) or the esc is limited in some way. Though im not so sure and i would advise to tackle mechanical part, if not great results for mechanical, then you can look into upgrading / replacing electronical parts.
I showed you 2 pulleys, look my previous posts. Do you really have 15mm belts? It sure is harder to find htd3 15mm pulleys than 11mm ones…
