I just started testing my esk8 and found a problem. The erpm is only 7000 and the vesc wont detect the motor.
I think it would help if people knew your set up and maybe some pictures
click on terminal and type in “FAULTS”
wait a second… it says your only running 6.4v… Is that true?
If that’s what your meaning to do: You might get 5mph on flats Lower the minimum input voltage to below 6.4v volts if you want it to “work”
i have two 3s batterys what should it be
It should be at 24v
looks like you may have a weak connection somewhere. Do you have an antispark loopkey installed?
no but i have a 4mm hxt bullet to xt 60 then xt 60 to xt 90
i also had to fix a bulet connector on the motor they sent me it had solder in the wrong end.
Unplug, wiggle and replug all your connections. If you have a 24v pack and a bad connection, it may be sagging under load.
allright ill try that
i just notice the battery connectors get 3/4 of the way in the parallel connector then stop
Wait wait… parallel connector?
i think its a parallel connector
post up a picture please.
its a parallel i must of order the wrong thing
this is probly what i should of ordered https://www.amazon.com/Serial-Bullet-Battery-Adapter-Turning/dp/B01LYLI4KA/ref=sr_1_1?ie=UTF8&qid=1506895881&sr=8-1&keywords=4mm+hxt+bullet+connectors+series
parallel should still be giving you 11 volts…
but series is what you need
