Hi everyone, I have been going back and forth on this one and would appreciate your comments.
I build my own 6s7p battery (NCR18650) which takes up so much space that I will very likely never go above 6s. Given that, what would you recommend, the FVT120A or the HK VESC (“turnigy esk8 esc”)?
Other parts
- 70mm wheels (will upgrade to 90mm eventually)
- HK motor mount + pulleys. 15mm belt. Gears: 15 (drive), 36 (wheel)
- SK3 6364 245kV
Been running all that through the esk8 calculators out there, amp draw, top speed etc. are all within limits and ok for me.
However, I keep reading 6s is at the Amp limit of the VESC, so higher risk to fry it (already seems quite high risk anyways…). The VESC mosfet’s limit is 50, and I want to be able to draw at least 50 or 60 battery amps to have enough power for the board. So I would definitely operate at the limits, especially when I upgrade to 90mm wheels. Is the VESC with 6s worth the risk?
I am guessing the FVT 120A with the “161214” (brakeLine / linear brake) firmware will hold up better with 6s. At least there seem to be many more 6s builds out there that use this one instead of the VESC.
I dont mind losing the configurability of the VESC, if I get better reliability in exchange for less options and features.
So, whats your take on this one?
