I’m curious if there is a VESC that is available if you want to run a larger motor, say 80100 at above 12s. Say something up to like 18s?
EDIT: I guess I should rephrase my question as I’ve seen a few of the ones mentioned here before. Is there an ESC that goes above 12s that anyone here actually uses or has used on one of their builds? I don’t think I’ve come across any build that has had one, yet I’ve seen builds where 80100’s were being used in a dual setup, but I think if I recall the person just had VESC 6 for his ESC and I think those can be ran at up to 18s…
Even a VESC 4 can probably do 200A when cooled “properly”. The rating should reflect no need for additional cooling besides maybe normal airflow around the housing.
flier sucks in my experience compared to the vesc. the motor wont run any cooler and with some good heatsinks on the vesc surely you can get enough power.
