Hello, Do you know any of ESC, that supports Speed Control? I want to limit the speed of vehicle and not allow to exceed it. Is VESC equipped with that functionality? Is there any other, cheaper one that has it? I need it for 6s battery, LI ION, min 50A I would say
Any vesc based esc that can be programmed in vesc tool can have speed control. You can also set your remote for 3 speed or 4 speed (if it has that) as well. Simply set your remote on the highest speed it has setting in vesc tool and your remote will be set to do the rest changing the pwm signal to match the speed.
