Love this mod: https://www.electric-skateboard.builders/t/bullet-connector-shrink-tape-mod-how-to/9416?source_topic_id=46475
Thanks. I knew there was an old thread somewhere. That thread is soooo 20 17 though
I was just to lazy to retype my response… guess I should have quoted… lol
@banjaxxed This is a good tip! I had problem cutting strips as they tend to warp when cutting with not so fancy scissors…
The nail clippers will probably blunt and stop working. A pair of tough scissors is much easier
I just wanted to pass the idea that this is the one rare situation where cutting corners is actually a good idea
Ialways wonder when I see those pointy corners on the end of a positive pole if it could get bent under the ring or cut it’s way through to the negative can. Even if not they can short off something else; sharp, sticky-out current carrying things should be avoided in a pack getting vibration, that is all…hack
Yeh, I agree with you on this one… These sharp corners look like unfinished job to me… Dont really have any pictures of my strips but some of them I even cut round… In the shape of positive round terminal.
At least then I know if for whatever reason a direct impact hits that strip, it does not have a fckn sharp corner to bend and hit a cell directly… just an extra safety and works for aesthetic purposes also…
If there was such a thing a a single purpose cutters that could do it I would buy them, you know with a 10mm semi-circle end
Life hack #1, Wear a helmet that can help cheat death.
My nickel strips warped a bit too when cutting them. I put them on a smooth surface and rolled them like cookie dough with a roll of hockey tape. Good as new. I also rolled down all the edges on the pack as I built it too. Great tip with the clippers @banjaxxed.
Yeh I assume rolling with something hard might work nicely…
I hammered mine flat against smooth surface and they also looked better.
I got these “quilting hexagon templates”
Damn do they make hexagons easy.
They are on amazon, or just ask your nanny to borrow hers.
There are these things, might serve the purpose with two cuts you would get a round end. You can find different size radius is you look around.
Just need to raid the wife’s craft bin!
mmmm nice findand stay outta there!
Not sure they would be strong enough,more a pliers guy
One of my motors has been causing me so much trouble… One of the latest things was the stripped threads that made me loose all 4 screws securing the motor to the mount during a ride. lol.
Some people might drill and re-thread with a tap, others would use an insert…but this part of the motor is made out of soft aluminum, and rethreading would most probably lead to another stripped threads…and I don’t have tools for the threaded inserts.
So instead I took hex nuts small enough to fit on the inside of the motor, put the screws in (with added threadlocker…also made sure nuts and screws would not interfere with windings) and epoxied down the nuts to the motor. No more stripped threads.
Edit… I even added som nail-polish onto the bottom of the screw+nut for isolation. lol. Don’t know if it would help or not.
or just 3D print one
