Tycho
July 28, 2017, 6:10pm
#1
Desired top speed
12-18 mp/h (20-30 km/h)
The range should be 9-15 km (6-10 miles)
Wheels
83mm flywheels
Wheel pulley
With: 15mm
Teeth: 36
Motor pulley
Bore: 8mm
Theet: 15
Width: 15mm
Drive belt
Lenght: 265mm
Teeth: 53
Fit with 15/36 pulleys
Width: 15mm
Whatever Motormount I can find or you can suggest
Found this one
One 190kv motor
Turnigy Aerodrive SK3 - 6364-190kv Brushless Outrunner Motor
Gets power from 2 of these Batteries in series
ZIPPY Flightmax 5000mAh 3S1P 20C
( so it would be a 5000mAh 6S1P 20C )
Speed controlled by this VESC
Unik control HW 4.12
Or this one
Remote controlled by this
Enertion Nano-X 2.4Ghz Controller
Looks good on the calculator
This topic is much of a “statement” of where I am in the process
Feel free to comment.
I know it is on the lower edge of my desire, but was tolk a 190kv have a great boost, and would like to have that when starting and stopping on intersections.
Right vesc
How could you suggest to charge the batteries in parallel
bigben
July 28, 2017, 6:20pm
#3
If you’re going 6s then I’d go for a higher KV motor. Perhaps this one instead?
Tycho
July 28, 2017, 6:24pm
#5
great idear, get up in speed and still have a great hill grade, thank you
I have ur entire drivetrain for sale
Tycho
July 28, 2017, 6:25pm
#7
I allready have the Pulleys and belt, thank you.
Maybe you have a motormount?
It’s attached to the motor by circlip
Tycho
July 28, 2017, 6:39pm
#9
sounds interesting,
do you have a picture?
Tycho
July 28, 2017, 7:03pm
#11
how much for the motor mount only?
Cobber
July 28, 2017, 10:22pm
#14
You mention two batteries at 3s
Then using them in parallel? or is that just for charging?
That will only be 3s 10000mAh, or series will give you 6s 5000mAh. You will need 4 packs to get 6s 10000mAh.
JAG1
July 29, 2017, 7:41am
#15
hi, very good thread mate.
where did you get your pulleys and belt from?
Tycho
July 29, 2017, 8:58am
#16
I’m not interested but thank you for the offer
Tycho
July 29, 2017, 9:00am
#17
Was thinking of having two ZIPPY Flightmax 5000mAh 3S1P 20C in series .
Then it would be 5000mAh 6S1P 20C.
Tycho
July 29, 2017, 9:12am
#18
I bought them from johnny_261
still waiting for them to arrive
thank you!
