I have ordered a time ago some connectors and wires for building motor sensor wire adapters.
I have a limited amount of material laying for 30 adapters. You can chose your own length between 10cm & 30cm. Each cable has its own heat shrink and is further strengthened with hot glue inside the outer shrinks.
@L3chef yes that is possible. Send me your adress in pm. Most of the time shipping is 2 euro.
@Andy87 haha yes, I solder those wires on my own. Those wires are 30cm from the factory. So soldering is much easier. If it must be shorter it take more time. To cut etc
