(EU/BE) Looking for two reliable VESC
Hello everybody. I would need 2 VESC. I was planning to go with ESC first and then switch but maybe I can find them with your help. I am going to build dual hub set up, on the cheap side. I will probably use them in BLDC mode and not FOC, so I need two working VESC at a good price/condition (second hand too). If you have also all the necessary to connect them together even better (like for the Torque board ones Male to Male Servo Connector - VESC XT90 Parallel Connector - VESC CanBus Connector).
Thanks!
I have esk8.de vesc 4.12. Very reliable in FOC also. I did ~50km with it. Comes with bullet connectors and xt60. PM me.
Thanks for the interest but he has one. I am looking for two. Still seeking…
With focbox out of stock and god knows when everyone in the market is taking them like hot pancakes, a good reliable vesc that’s at a affordable price like u asked for is not going to be in stock any time soon
If you need it immediately, VESC6 from @trampa is probably your best option, if you have the dough for it.
EDIT: just realized you want it cheap. Try Torqueboards vesc if you aren’t using FOC
If I do not find a better deal with a second hand ones I will probably go with the Torque VESC. We’ll see it
Found one FOXBOX for you.
Good luck finding two.
Hey
I got some maytech VESC’s available (both used & unused)
check: https://electricboardsolutions.com/
I also have 2 new hobyyking 120A esc’s you can have for 50euro (included shipping)
You have hubs? maybe I can set you up with the double ESC from maytech? I just imported some of there double ESC’s :slight_smile:
Greetz Frederic
Just found two for you. I think they are still available.
https://www.electric-skateboard.builders/t/uk-eu-foc-boxes-sealed-maytech-motors-6374-170kv/45558?u=sayekim
Edit: Sorry the first post mentions sold at the bottom but perhaps they are not?
Thanks for finding it. I sent a message. We’ll see. I now they are reliable but also expensive! :joy:
I have seen your website, good that you are in Belgium too. I know maytech and it comes with not the best reputation lately. Altought they probably work fine in BLDC, if you don’t stress them in FOC mode. The DualMaytech VESC is a cool solution but I am afraid it won’t differ to much from a normal ESC. The specs are a bit low. If you have fully functional second hand VESC please pm a quote.
Thank you Thank you
Faradaymotion Vesc’s are awesome. They are working directly with Benjamin V. I’ve ~500+km on their vesc in FOC mode
Thanks for the advice, I will think about. The VESCs are so expensive…:sweat_smile:
I think you can get 20% of the vesc’s if you ask for a winter discount coupon. :slight_smile:
