Hey guys
I just designed a first prototype and 3D printed it to test fit, I’m not there yet… Any good ideas to improve?
It’s even with the 80mm otangs a bit to small, center distance is 85mm. I can’t move the idler pulleys closer to the motor because the nuts of the bolts that hold the idler will touch the motor. I could make the plate even longer but that makes it more bulky and a longer plate will put more stress on the clamp.
Also would it better to have slots for the idlers instead of for the motor? I did it like it is now so the plate can be used without idlers aswell
Grtz
Frederic
If possible the idler shouldn’t be longer than the belt. Otherwise you can’t use bigger wheels like 107mm.
Yes, or I could use longer plates but I don’t like them to long
Idlers that sit flush with the belt would be great. In this case you could try to move the mount a bit away from the wheel so that you have like 2 mm distance between the belt and the wheel.
My enertion pulleys have a gap of like 2 mm to the wheel so a idler that ends at the belt would be perfect.
What is flush?
I will see what I can change, the bolts I used are to big anyway, it was just to test fit
You mentioned 10 days ago that then was the last day for the mount preorder, but the it’s still available on your page
So can I still buy it?
yes you can still order, I forgot to take it offline, I will do it after your order
Thanks, I can’t order it till tomorrow though.
I ordered the kit with caliber trucks.
Thank you once again for letting me order them
All mounts are out and everyone should have gotten an email with tracking number
For the interested
I’m doing a pre-sale on the ABEC11 drivetrain: https://electricboardsolutions.com/collections/kits/products/abec-11-dual-sensored-drivetrain-pre-sale
props dude. that actually looks really good
Just recieved my mount and trucks, they look good. Thank You.
