[EU] Looking for a dual vesc 4.20 plus and a deck
Hello everyone, looking for a dual fvesc 4.20 plus (with the antispark) for my next build. I’m don’t have that much of a budget so lower the better, used or not as long as it works :man_shrugging:
Also, I’m looking for a drop down deck that can fit pneumatic (5/6 inchs or 145mm to 152mm for non retards unit), without riser (or a small one) : if you have a good and cheap deck lying around, or recommendations (I discovered skateshop24 few days ago thanks to one of you), it would be perfect !
Well, that’s it for now folks !
T’as des 4.20 a 100€ sur esk8fr !
I have dervish flex 2 but shipping is killer
Je cherche du dual, plus pratique
Mais je te parle d’un dual gogolito
mais le plus ? parce que le 4.20 dual normal est pas assez puissant
J’ai deja acheter les deux du forum de toute façon. Mais il me l’a vendu en m’envoyant des tests et il n’a eu aucun problème jusqu’à 40A en 10S.
