A complete setup, just add a board to have fun!
Mellow is the first ever drive system for skateboards that can be mounted under any deck. Just unscrew your rear truck and replace it with the Mellow Drive – simple as that.
•Quality product „Made in Germany“ •Weight incl. battery 3,9 kg (8.6 lbs) •Size 366 x 174 x 59 mm (14 x 7 x 2.5 inches)
The Motors
•Two in-wheel motors •Torque 3 Nm each •Topspeed 40 km/h •Maximum Grade 20% •Water and dust proof (IP65) •Freewheeling when you push •Exchangeable wheels
The Frame
•Solid magnesium singleframe •Standard 6-hole, 180mm truck •Click-in mechanism for the battery
The Battery Pack
Quality lithium ion cells from the Tesla supplier with a Battery Management System (BMS) that protects them from overheating, deep discharge and too high currents.
•Range 12km - 15km (7,5 miles-10miles) •Charge 3,5hrs •Fast Charge 45min •Full charge cycles 1.000 •Weight 1000 g •Energy 99Wh •Swappable via click-in mechanism •Certified for airtravel •Water and dust proof (IP65) •Powerbank with USB port
The Mellow Remote
The custom-built Mellow slide control gives you perfect control over throttle and brake.
•One button device •Switch between 4 riding modes •LED displaying state of charge •Vibrating alert before discharge •Rubber coated for better grip •Safety wrist strap •Encrypted bluetooth connection •Size 110 x 36 x 23 mm (4.5 x 1.5 x 1 inches)
The Brakes
Mellow has a dual braking system that #1 regenerates your battery and #2 still works when you are fully charged. Whereas most of the existing rides switch their brakes off at that point.
Front truck
Matching the truck of the Mellow Drive Width 180mm Base Plate Angle 45°
Front wheels
Mellow Wheels: custom made for the Mellow Drive Easily exchangeable with a normal skateboard tool Sizes 80mm Hardness 80a
Price: 800 euro
