Hello,
I see that there is a lot of interest in cheap Li-ion battery packs.
I have a spotwelder so why should I not get into the market
I live in Belgium so i can ship to the whole EU.
Pack specs: You can choose your own battery configuration. For the pack i use 12x0.15 40A 99.96% Pure Nickel. I use always two layers of strips so the max current is 80amps. The output wires are 10 awg silicone wire (max current 120A).
Price List: Price per cell included spotwelding LG IMR18650-HE2 2500mAh - 20A β¬3.99 Samsung INR18650-30Q 3000mAh - 15A β¬4.99 Samsung INR18650-25R 2500mAh - 20A β¬4.39 Sony Konion US18650VTC6 3120mAh -30A β¬5.99 If you want you can ask me for other cells
Options: LCD Battery Indicator/Voltmeter β¬10 Switch for BMS β¬2 Balance wires for BMS β¬5 PVC wrapping β¬5 Output wires β¬2 XT-90 β¬2 BMS-50A β¬60 BMS from besttech (for price i must contact them)
All prices are an indicator, there may be slight changes (cheaper or more expensive) based on the configuration and type of cells **
Two own battery packs in building. When i am ready i go post photos.
