I have hundreds of these cells, brand new in original packaging left from a larger EV project. Prices depend on how many you want. Since I’m in Germany, I think shipping only makes sense within Europe.
I also have a spot welder, so if you’d want me to create a pack for you, that could be arranged.
You should however consider that above 15A draw per cell, they produce more heat. so at 2P, 30A constant draw is perfectly fine, and while the cells can deliver 30A per cell, since eskate batteries usually don’t have ventilation, they’ll get much hotter at that current draw which may reduce life. so don’t plan for your board to draw 60A constant. that should be the absolute maximum.
oh and do you only need balance leads or a certain plug at the end? because depending on the bms board you want to use they can differ.
No. They’re 15A continuous under any case. 30A continuous with temp cutoff at 80C and burst up to 40A for 40 seconds, 50A for 19seconds or 80A for 6 seconds
Hello, do you still have those cells?
I would be interested in 60 pcs, with no welding at all, only the cells. If you could give me a good price, I’m really interested in them.
