Was super lucky to get a “Free” Gt battery for my project, but one problem I’m running into would be the BMS, does anyone know a BMS I can use with it or a way to charge it without having major problems?
Welcome to the club bro. They are very hard to get hold of!
The genuine Evolve BMS is yeah, but im using focboxes instead of their esc so i should, in theory, be able to use any bms since i don’t need to use those extra wires into the esc
any 10s bms on the planet?
Would any 10s li-ion bms work? Not sure if the balance layout is the same thats just it
I’ve been looking for a BMS as well, the only one that I’ve bought so far is this. Have you had any luck finding one?
Another one I have found that has an e-switch & a uart setup is here but I am not sure if it is necessary to buy.
I just got a chinese cheapo ESC of ebay seems to work fine
Nice, would you mind sending me a link? I’d like to have a backup in case the one I ordered doesn’t work out.
I dont really have a link sadly, just got it used of a guy here in Denmark but any BMS rated for like 40 or so amps for the correct voltage and cell count should work
But its from ebay, its white and rated for 40amps 10s.
Anyone have any luck with the ? The two above linked by @Kit have the wrong discharge voltage protection.
