Hi,
My friends went on my board, 2 of them at once, and as they accelerated to quickly, it shut down. I also know this is a preventative measure so as not to fry all the electronics but this is different. Now if I was there I would have said not to do it so no point telling me it is my fault because i have read a lot on the forum and are aware of evolve’s ‘‘weird’’ quality.
The board will not turn on, or at least the blue light on the power button does not flash.
I have taken the board apart and it smells like something is frying on the ESC. I don’t think it is the BMS because when I try and charge it, the red light comes on the charger signifying it is charging.
the ESC also heats up (like untouchable hot) immediately when I turn the board on in one particular spot below the evolve logo on the ESC. it seems like it comes from a little black square below. pics below.
Also, when I took the cover off, the yellow lead from motor 1 was unsoldered. just above it, is where the heat is coming from. I have now re-soldered it back.
Any help is appreciated and if someone now the price for evolve to repair or is selling an Evolve ESC then please DM me.
I had mine recently shut down. And I found out that one of my capacitor leads had a broken solder joint.
You can see in the pic. The lead closest in the pic was just barely touching.
Not saying this is your problem. Just inspect the board with a magnifying glass to see if anything looks suspicious.
And inspect the pins if any are bent or missing.
Sure but do I have the money for a Unity and a BMS? 300 plus euros?
not sure lol. I have taken it apart and looked carefully I will post detailed photos of the whole thing and show where it is heating up. @Crashmaster if you can take a peep to see if you can spot anything
Negative. The blue light on the power botton does not flash when i press it. I pulled the esc apart and looked at it then put everything back and pluged in only SWITCH, UART and BATW, leaving the motors and hall sensors unplugged and got zero response from the board except as i said when i turn it on it immetiately heats up as i showed in the pics above with a yellow circle.
The 2 black components that are circled are voltage regulators. The small one is a LDO and the large one is a linear.
A linear regulator dissipates heat proportional to the amount of voltage it must drop, and the amount of current flowing through it.
Even if this was in front of me it would be difficult to trouble shoot assuming the 2 boards need to be together to work properly enabling to test with a meter.
I’m no expert. And not a electrical engineer.
But I have done board repairs in the past on other equipment.
Unfortunately it’s starting to be a lost art due to it’s easier to replace the board than try to trouble shoot a board without schematics.
I only know of a few people who do enjoy doing this type of work.
I am just going to have to get a new ESC I think.
I have contacted evolve France (because that is where I live) to see what they have to say.
They are really rude though and quite unhelpful so we will see.
@Crashmaster So 179 euros for an ESC, 40euros/hour for repair, 40 euros total for shipping (return) and if it is the BMS it costs 39euros.
So a Min. of 259euros.
I say perso get a unity and sell evolve remote. What do you think?
With your knowledge do you agree that the chances of the problem being the battery/cells being fried is minimal? if something went wrong it is either BMS or ESC right?
I dont think is the bms because I had the same problem couple times and if smells like is frying looks like is the controller ( esc ) and You dont need to send your board just ask them for a replacement. No shipping and no labor. Also you could find on eBay for better price.
It’s a decision you need to make.
If you want to be stuck using the Evolve stuff and dealing with the high prices of replacement parts their service.
Or Go aftermarket were you have more options to choose from,
Eventually by the end of the year I’ll be changing over to an aftermarket Bms and Esc’s and controller to get out of being stuck with their stuff and not having a option for how I want my board to perform.
