post the screen shots showing the settings you have been changing
I have two APS motors (no sensors) on two Enertion Focboxes. Motor detection failed on both Vescs and motors were going full on spastic. It only worked when I increased the duty cycle from 0.05 to 0.08 ish.
- Flipsky dual 6.6 plus
- VX2 remote
- Evolve GTX gen2 motors
- Set to FOC
- Current brake, no reverse
- V0 & V7 = true
- High Current = true ( without these it doesnt work)
- motor Current 45A, regen 30A
- ERPM 40000
- Latest firmware, reflashed multiple times
- Both VESC identical settings
- 10S 10000Mah
- Max Duty 95%
- Min Duty 0.5%
- Min Volts 8V
- Max 42V
- CAN rate 50hz
As I`m putting these deets in, looking at the VESC app, the ABS Tacho is counting away slowly.
Ill post screen shots in a bit
actual screen shots would be better
