Use promo code: 40%OFFEVOLVE www.hyperionesk8.com
3D PRINTED BAMBOO GT RISER
EVOLVE ALUMINUM HEATSINK FOR DUEL FOCBOX
What’s the dimension of the dual focbox heatsink?
Do the motor guard/bumpers fit 63mm motors or just stock?
The bumpers only fit the stock mounts
Evolve 3D printed riser for GTX Bamboo Boards Battery upgrade 18mm kit is four (4) pieces, right?
yes, it is the best so far and matches the enclosure well and has thickened walls for the added weight
‘Bamboo Boards’ means is all across the Series, no? That means it also works on the ONE either? Evolve Bamboos share the same enclosure as far as I know. Your 3D printed riser follows suit, right?
correct, depending on the age of the enclosure, so far it has fit even the oldest we have seen
Not to worry. Is the latest. You can even smell it came out of the oven …
So, with 18mm more riser space what would be the largest battery you can stretch across, from one end to the other, if I also put a riser over the heat sink square opening to rise (put down) VESCs and BMS? I also got @thisguyhere heat sink for Focboxes, so for those too, how tall that riser should be?
ok, in order to do that and completely clear the focboxes your additional riser would need to be 22mm or 7/8 of an inch
the heatsink is 5mm thick or 3/16
the fockbox PCB resistors (wire room) is 17mm or 11/16
So 18mm Enclosure riser and then additional 22mm for the second Heat Sink riser. You say that will be enough for installing the longest 18650 cell battery system possible inside the Enclosure? and will acomodate Focboxes and cabling inside the Heat Sink raiser space provided below?
Depending on your bms (stock evolve bms will limit your parallel number to 5) and how you manage the phase and sensor wires and how you use the 1 1/2 space provided. I think you can get the biggest battery to date. 12s7p or 10s8p or bigger
Corey, PM sent.
How much for the 66t wheel drive ? I need some for my mbs rockstar
for the money you would spend on the 66t $80 nylon gears you can get some sweet aluminum 72T gears for like $40 more
but, to answer your question on the nylon set, i believe with the sale its like 50$
