That Flipsky switch is like an alternate switch.
Firmly coat the cable so that it is not cut.
Should the cable be broken, the VESC will also be powered off.
Unity is a momentary switch.
Momentary power turns on by momentary energization, and turns off again by momentary energization.
In the case of Unity, it seems that the power will not turn off even if the cable is broken while driving.
Of course I have not tried it.
The cable has never been broken.
In the case of the alternate switch, make a particularly robust connection.
The shorter the cable, the more robust it is.
Using very thick insolated cables and kapton tape over each line with a rubber coat on the deck where everywire is so that should prevent any damage or cuts.
But yeah its a bit long, i know when you do power wires you add something but on these you dont add like a res or cap?
It is important to be able to keep the power on.
A cable extension of about 60 cm seems to have no electrical problems.
Physical problems such as broken cables due to vibration etc. are more scary.
Alternate switches are a bit scary.
The momentary switch can extend the cable more safely.
In the case of momentary switches, the only problem is when turning the power on / off.
It is not necessary for the VESC to turn off, even if the cable is broken while riding.
