10s 5amp $35 5.5mm x 2.5mm barrel 1lb
10s 8amp $55 5.5mm x 2.1mm barrel 2lb
12s 8amp $60 5.5mm x 2.1mm barrel 2.5lb (aluminum/silver color only)
buy more than one and I can save u a few bucks, no bulk rate tho sorry
plus shipping, local pickup in nyc. If youre feeling ambitious on calc. shipping charge it comes from 06854 (can possibly save u a couple bucks on the heavier units)
Ride hard, charge fast! Only a few available so first come first serve… If you have a 2.5mm charge port i have some converter plugs I can include.
Testing during charging showed it was within advertised tolerance.
For 8amp - If you have any concerns about your charging wiring I can provide a 3.5mm bullet connectors… You however will have to solder them on.
As a side note 20ga wire is rated at 12amps, and 22awg at 8amps (roughly) so most builds built properly should be sufficient.
A red JST is rated at 5amps so charging at 8amps is recommended to upgrade to either bullet connectors, xt30 (minimum) or a deans… what ever fits your fancy.
If u wanna pay shipping then sure… Youd also need a plug converter or you can cut the wires on your own and resolder… Yur choice… Lemme know if interested… Ships from 06854 if you want to price it
yeah cells can handle 4amps each… so a 4p would be good up to 16amp or 32 for you 8p… i saw a 15amp charger the other day… its like a fucking mini computer tower lol…
22 is the minimum at 8amps… 20 would be fine as that s rate for 12amps… the only thing i changed was my jst connector as theyre supposedly rated at 5amps… so 3.5mm bullets… xt30 or larger… deans connect… any of those are more than enough IMO
if you dont have anything bigger than the 22ga on hand you could just use two pieces side by side as well…
yeah youll be fine… what i noticed from most of my prefabbed batteries that most had 20ga wire so thats what i bought before i schooled myself on amperage specs n stuff… this last build i used 18ga for OCD insurance =P
you cant hijack my for sale thread, bad form… anyways… maybe same price with shipping but no actual ship date… couldt be a week could be a month… if im in a hurry i buy domestic and eat the cost its not a biggie if you want it that bad…
sorry, i wasnt aware it was a for sale thread, i thought it was information sharing since i saw someone else link a charger as well… ill remove the links.
