F005T3D DUAL+ 2nd build
For my second build, inspired by Skatemetric, I’m going to be making a Foosted Board. The reason for this “Dual+” part is for it’s upgrades in the VESC, battery, remote (@solidgeek). I made a doc and if you guys could talk about things I could improve pls say something.
I’m building my Firefly remote right now, but need to shorten my wires as I made them way to long. Any suggestions or ways to cut down the cost, im right here!
great build! happy to see the remote! for some reason my other comment got flagged as “spam”.
Just a quick one, on your form it says you are buying two unities. You’ll only need the one for your build.
Also don’t buy anything, even small parts from Mboards. He’s a clown and his business is a joke. He’ll make you wait months for those little parts. Might as well just get them from a reputable seller.
Not sure if your spreadsheet is a work in progress but your amounts don’t add up :smiley: Put some sums on that badboy.
=sum(D3:D22,G3:G22) for your total
=SUM(C3*B3) on your motor totals and drag it down to replicate the formula
Amount: Cost Each: Total: Where: Link: Shipping: Discounts: Amount Cost: 1633.29
Mechanical:
Motors 2 180 360 Torqueboards collections/electric-skateboard-power-kits/products/dual-motor-electric-skateboard-kit 0 8.985
Motor Mounts 2 73.32666667 146.6533333 Torqueboards Kit collections/single-motor-mechanical-kit/products/single-bolt-on-motor-mount-w-drive-wheel-kit 0 N/A
Wheel Pullies 2 73.32666667 146.6533333 Torqueboards Kit collections/single-motor-mechanical-kit/products/single-bolt-on-motor-mount-w-drive-wheel-kit 0 N/A
Motor Pullies 2 73.32666667 146.6533333 Torqueboards Kit collections/single-motor-mechanical-kit/products/single-bolt-on-motor-mount-w-drive-wheel-kit 0 N/A
B Enclosure 1 50 50 Eboard Peru https://www.eboardsperu.com/product/10s4p-battery-for-loaded-vanguard/ 17.5 N/A
V Enclosure 1 50 50 Eboard Peru https://www.eboardsperu.com/product/10s4p-battery-for-loaded-vanguard/ 17.5 N/A
0 0
Electronics: 0 0
Battery 1 350 350 Hyperion1 on Forum hyperion1 0 N/A
ESC/VESC 1 296.72 296.72 Enertion https://www.enertionboards.com/focbox-speed-controller/focbox-unity-dual-motor-foc-controller-esc/ 0 N/A <-- CODE: XcStEg
Remote 1 38.26 38.26 Firefly Remote https://www.electric-skateboard.builders/t/simple-3d-printed-nrf-remote-arduino-controlled/28543 0 N/A
0
Other: 0
Connector 1 7.5 7.5 mboards.co 3.86 N/A
Riser 1 1.99 1.99 mboards.co N/A
0
Normal stuff: 0
Calliber Trucks 40 0 Amazon https://www.amazon.com/Caliber-Trucks-Cal-50°-Longboard/dp/B072J845HD/ref=sr_1_3?ie=UTF8&qid=1543188763&sr=8-3&keywords=caliber%2Btrucks&th=1 0 N/A
O'tang Wheels 60 0 Amazon https://www.amazon.com/Orangatang-Downhill-Longboard-Skateboard-Cruising/dp/B07CLMPP98/ref=sr_1_2?ie=UTF8&qid=1543188548&sr=8-2&keywords=orangatang+wheels 0 N/A
Zealous Bearings 15.99 0 Amazon https://www.amazon.com/Zealous-Bearings-Skateboards-Longboards-Steel/dp/B00BL9VCRE/ref=sr_1_1?ie=UTF8&qid=1543188785&sr=8-1&keywords=zealous+bearings 0 N/A
thanks!!!
what do u mean they don’t add up?
