So I am looking to make a final build Ive been doing a few for other and my personal I managed to fix up and get running again which was 6s 10000mah 245kv. I’ve been learning and building electric skateboards for about 1.5 years nowand Now I’m ready to build one of the best that can be made. A few questions though for the community about the most efficient and durable parts. dual or single? Im thinking single since it consumes less current and increases battery life, however there is also hub motors but are they currently efficient? From what I am able to deduce they are less efficient than a pulley driven system. Then for the esc Im thinking about either the vesc or fvt 12s however the vesc has not been known for long life, but I also know that @chaka has made some that have lasted people years. Finally the battery, is 12s truly more efficient than 10s? I know increased voltage means more efficiency but is that truly the case if you’re putting more stress on the components at that voltage? Im willing to put in around 2000 maybe more if necessary, what I truly want is something that can just function as well as a boosted but as powerful as a DIY build.
Edit: Its not that I don’t know what to do, its more so everyone has their own viewpoint and id like to learn from everyone mistakes, and you can never truly know it all.
