Hi, hope you guys can help. Haven’t found this problem here.
I installed Flipsky dual 6.6 Esc. Works fine.
Problem is that at very low rpm, when I want to accelerate with the remote (maytech), instead of acceleration the esc applies the brake.
This only at low speed. At faster speeds all is fine.
Is this a constant issue? Have you tried simply reconnecting the controller? When connecting it will change your input deadband if brake/throttle is applied in the slightest.
Hi Fourteeoz
Yes, constant issue.
When I slow down, at slow walking speed, when I want to accelerate the motors start braking and stutter for about 2 sec and and then start accelerating.
So its from low rpm - to near a stop when accelerating and then finally pick up speed.
It nearly threw me off. Now that I know I can adjust, however if this happen doing jumps or slow carving , I be on the ground.
One more thing: its not the same like what has been discussed in other treads I believe.
Its not an stuttering or jitteriness at low speed.
Its an effective braking when pulling the remote trigger to speed up from low speed.
