Hello everybody. Right now I’m looking for a good charger for my esk8. I currently have a 6s bms, powered by two 3s 5000 mAh LiPo’s in series. Those LiPo’s are connected to a 6s 12A BMS. I had a charger first, but it was slow and I broke it by letting it slip out of my hands. So right now I’m looking for a new affordable charger. And with that I was wondering what the most powerful safe charger is for my set-up.
P.S. Does anybody know how to calculate charge time?
Lipos are fine up to 2.5c… you should see my 44ah field charging pack that I charge at 110amps. Lipos take charge alot easier then li-ion and typically have half of the IR a Li-ion does…if not lower…
These are power supplies, not chargers.
They will not work unless your batteries incorporate a charging circuit . Most eskates have a BMS so you should be ok.
I am afraid if you want to charge lipos properly you will have to fork out some cash and get a decent charger.
Is that a marine type lead acid battery?
These have a very low IR and can charge and discharge at very high currents.
I use a 1600kva generator, 2x modified server power supplies and a 1344W charger to charge my lipos at 4-8C without any ill effect to the batteries. When time permits I go for the lower charge current though.
Nice.
I fly RC helicopters but I needed a generator because my 700 uses up 2x 6S 5000mAh batteries every 6min.
That means that if I want to fly for more than a few times I need a generator or a couple of big capacity marine type lead acid batteries (and these weigh a lot more than my generator).
