FatBoy Mini Eco Gear Drive 1:3.5 for TorqueBoards TB218 Trucks works with 6" wheels and Bergmeister wheels.
Wheels Fitting:
Motor Fitting:
TB218: 6355, 6365, 6374
Kit Contains:
2 x Motor spur gear (12 tooths) (for 8mm shaft)
2 x Wheel Hubs with gear (42 tooths)
2 x Hanger mount adapters (Three positions -15º, 0º, +15º)
2 x Baseplates with the motor mount holes
2 x Gearbox covers
2 x V-Ring
2 x Stainless Steel Slid Plates for V-ring
Screw kit
Loctite 638
Loctite 243
2x FatBoy Mini Eco Gear Drive weighs 840 g.
Price: 218€ + VAT + Shipping
Starting taking pre-orders will start manufacturing after Paris Event so expected delivery is end of July.
With 6" Wheels
With Bergmeister wheels
Impressive price, would 6380s fit?
The difference with the nano is the gear ratio? They seems identical. Would be possible order the gears only for the guys that ordered the nano? (If they fit)
They look similar but they are different internally this is made for AT wheels so many things are different.
Can you compare the differences? It seems the adapter is a bit easier to use for the Haggy, however the rest (with exception of the gear ratio) seems pretty similar. No?
No, like I said its entirely different design, gear width is different, mounting stuff is different its more mini AT version than nano which was made primary for urethane.
Maxid
July 4, 2019, 9:50am
8
Is there a way to fit the 5065 racerstar motors (like: only use two screws to hold the motor or a 3d printed adapter plate)?
It’s possible to make adapter plate if needed
Are 190-200kv okay with these? Or are you targeting more 150-170kv with this ratio?
Will these work with the 6" wheels that @dickyho sells?
Yes, we used them to test it
It depends on your preference, what you want speed or torque
If I ordered the 6" kit can I get an adapter when I upgrade to Bergs later on…
Yes, you can buy separately adapters for Bergmeister wheels .
Maxid
October 23, 2019, 9:46am
17
How do the gears inside actually look like? There is like no picture of this thing opened up.
How much are they how long to get them to wisconsin need a set to fit my trampa trucks
