I built a newish esk8 and it seems to stall for a few seconds if I go over even the smallest bump and sometimes at random. On some rides its fine and only stops once or twice but other times it will stop every few seconds making it impossible to ride. I have about 20km on it so far.
I have tried setting the motor max and batt max lower and increasing the absolute max but it doesn’t make a difference. The voltage during the faults seems to be incorrect because my battery was at about 40v but the fault reported it as ~31v
Specs: 10s4p Samsung 25R battery pack 190kv torque boards motor FOCBOX 82mm wheels 16t/36t
FOCBOX settings
Here is the faults:
The following faults were registered since start:
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 134.6 Voltage : 31.95 Duty : 0.61 RPM : 66.1 Tacho : 11582 Cycles running : 5976 TIM duty : 4010 TIM val samp : 1898 TIM current samp : 5165 TIM top : 6534 Comm step : 6 Temperature : 25.11
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 136.2 Voltage : 32.49 Duty : 0.49 RPM : 1018.6 Tacho : 14980 Cycles running : 12639 TIM duty : 3890 TIM val samp : 1797 TIM current samp : 5805 TIM top : 8017 Comm step : 2 Temperature : 25.37
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 130.5 Voltage : 31.87 Duty : 0.61 RPM : 301.2 Tacho : 17822 Cycles running : 8706 TIM duty : 4011 TIM val samp : 1899 TIM current samp : 5162 TIM top : 6527 Comm step : 6 Temperature : 25.57
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 135.3 Voltage : 31.25 Duty : 0.58 RPM : 109.5 Tacho : 21202 Cycles running : 7000 TIM duty : 3979 TIM val samp : 1872 TIM current samp : 5328 TIM top : 6912 Comm step : 2 Temperature : 25.70
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 134.6 Voltage : 32.69 Duty : 0.46 RPM : 14.8 Tacho : 34218 Cycles running : 4464 TIM duty : 3862 TIM val samp : 1773 TIM current samp : 5952 TIM top : 8358 Comm step : 4 Temperature : 26.26
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 137.3 Voltage : 31.93 Duty : 0.56 RPM : 10.8 Tacho : 43024 Cycles running : 5463 TIM duty : 3963 TIM val samp : 1858 TIM current samp : 5417 TIM top : 7118 Comm step : 2 Temperature : 26.95
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 137.7 Voltage : 30.48 Duty : 0.58 RPM : 120.1 Tacho : 51802 Cycles running : 83770 TIM duty : 3987 TIM val samp : 1879 TIM current samp : 5288 TIM top : 6818 Comm step : 2 Temperature : 28.13
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 34.9 Current filtered : 130.0 Voltage : 35.66 Duty : 0.75 RPM : 72.5 Tacho : 56634 Cycles running : 5598 TIM duty : 4094 TIM val samp : 2044 TIM current samp : 4790 TIM top : 5492 Comm step : 4 Temperature : 28.63
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 133.4 Voltage : 32.10 Duty : 0.53 RPM : 512.7 Tacho : 63772 Cycles running : 28521 TIM duty : 3942 TIM val samp : 1841 TIM current samp : 5530 TIM top : 7378 Comm step : 2 Temperature : 28.86
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 138.0 Voltage : 30.59 Duty : 0.59 RPM : 529.1 Tacho : 69922 Cycles running : 2652 TIM duty : 3991 TIM val samp : 1882 TIM current samp : 5268 TIM top : 6773 Comm step : 2 Temperature : 29.07
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 134.6 Voltage : 32.36 Duty : 0.46 RPM : 5.0 Tacho : 83308 Cycles running : 30138 TIM duty : 3860 TIM val samp : 1771 TIM current samp : 5964 TIM top : 8386 Comm step : 2 Temperature : 28.91
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 131.2 Voltage : 32.70 Duty : 0.50 RPM : 0.1 Tacho : 87450 Cycles running : 16334 TIM duty : 3910 TIM val samp : 1813 TIM current samp : 5700 TIM top : 7773 Comm step : 4 Temperature : 28.84
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 132.3 Voltage : 32.21 Duty : 0.57 RPM : 1034.2 Tacho : 90224 Cycles running : 6665 TIM duty : 3978 TIM val samp : 1871 TIM current samp : 5337 TIM top : 6932 Comm step : 2 Temperature : 28.78
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 136.6 Current filtered : 130.6 Voltage : 39.89 Duty : 0.20 RPM : -0.0 Tacho : 94361 Cycles running : 0 TIM duty : 840 TIM val samp : 1995 TIM current samp : 4095 TIM top : 4200 Comm step : -1 Temperature : 28.86
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 0.4 Current filtered : 133.6 Voltage : 40.20 Duty : -0.00 RPM : 1117.7 Tacho : 122334 Cycles running : 26070 TIM duty : -263 TIM val samp : 131 TIM current samp : 26505 TIM top : 52747 Comm step : 6 Temperature : 30.04
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 132.9 Current filtered : 130.2 Voltage : 39.89 Duty : 0.19 RPM : 1.6 Tacho : 125973 Cycles running : 0 TIM duty : 780 TIM val samp : 1995 TIM current samp : 4095 TIM top : 4200 Comm step : -1 Temperature : 30.33
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 132.1 Voltage : 32.10 Duty : 0.60 RPM : 60.4 Tacho : 125980 Cycles running : 1052 TIM duty : 4001 TIM val samp : 1891 TIM current samp : 5211 TIM top : 6640 Comm step : 6 Temperature : 30.39
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 130.7 Voltage : 32.36 Duty : 0.49 RPM : 288.1 Tacho : 130440 Cycles running : 5537 TIM duty : 3895 TIM val samp : 1801 TIM current samp : 5777 TIM top : 7953 Comm step : 2 Temperature : 31.32
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 131.2 Voltage : 32.25 Duty : 0.56 RPM : 87.1 Tacho : 313108 Cycles running : 2956 TIM duty : 3968 TIM val samp : 1863 TIM current samp : 5390 TIM top : 7054 Comm step : 6 Temperature : 37.25
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 130.7 Voltage : 31.96 Duty : 0.56 RPM : 73.4 Tacho : 323712 Cycles running : 41463 TIM duty : 3968 TIM val samp : 1863 TIM current samp : 5387 TIM top : 7048 Comm step : 6 Temperature : 36.39
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 119.1 Current filtered : 131.0 Voltage : 39.96 Duty : -0.00 RPM : 2689.1 Tacho : 335749 Cycles running : 67253 TIM duty : -263 TIM val samp : 131 TIM current samp : 26505 TIM top : 52747 Comm step : -1 Temperature : 37.34
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 131.6 Voltage : 39.80 Duty : 0.00 RPM : 768.8 Tacho : 351287 Cycles running : 0 TIM duty : 0 TIM val samp : 247 TIM current samp : 2347 TIM top : 4200 Comm step : -1 Temperature : 37.80
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 139.7 Current filtered : 130.2 Voltage : 39.62 Duty : 0.00 RPM : 483.7 Tacho : 365831 Cycles running : 0 TIM duty : 0 TIM val samp : 183 TIM current samp : 2283 TIM top : 4200 Comm step : -1 Temperature : 38.09
Does anyone have any troubleshooting ideas or can see anything wrong with my setup. I have looked through a bunch of threads here but I cant seem to find anything that relates to this. EDIT: It happens at any speed including slower than a walking speed.
