I am working on a dual 6374 build and have a gremlin problem.
I am getting FAULT_CODE_ABS_OVER_CURRENT on both FOCBOXes but only when both motors are running via CANBUS. I can run the individual motors/FOCBOX without issue.
Fault : FAULT_CODE_ABS_OVER_CURRENT
Current : 86.1
Current filtered : 135.7
Voltage : 37.79
Duty : 0.52
RPM : 37191.9
Tacho : 16403
Cycles running : 28
TIM duty : 3932
TIM val samp : 1903
TIM current samp : 5652
TIM top : 7498
Comm step : 2
Temperature : 30.70
So far I have replaced:
FOCBOX x 2
Bullet Connectors
BMS
Remote and RX module
Do you have any mechanical symptoms? Stuttering? Weird noises from motors?
I had this issue on rspecs because they were shorting out, totally unnoticeable for the first while, so I ignored it, kept riding for a few weeks until it started randomly throwing full brakes (shorting) on me.
Maybe its your motors? In my professional noob opinion.
I am running sensorless BLDC without an issue. I will check the sensor cable wiring tomorrow, but it’s weird that the both the motors detected the sensors okay and run independently in sensored mode without an issue.
this is odd! I have built more than a few dual boards using my 6374s and dual FOCBOX without this issue. I did extend the phase leads so I suspect that must be the cause.
did you found the problem?
I have a similar problem.
Motor detection running without problems.
but I get the fault when sensor is connected.
if disconnect sensor wires no fault at all.
