I have the same issue with my flipsky dual 4.2 too. Also with lipos as 12S (max current can be 300A).
If I lower my cuurent setting, it is better, but still, there is some issue there…
Fault : FAULT_CODE_DRV
Current : 43.4
Current filtered : 40.0
Voltage : 44.94
Duty : 0.878
RPM : 39479.1
Tacho : 50115
Cycles running : 3068
TIM duty : 4155
TIM val samp : 2078
TIM current samp : 4446
TIM top : 4736
Comm step : 3
Temperature : 38.41
Current : 48.3
Current filtered : 48.6
Voltage : 45.82
Duty : 0.873
RPM : 39771.7
Tacho : 53298
Cycles running : 3178
TIM duty : 4152
TIM val samp : 2077
TIM current samp : 4456
TIM top : 4758
Comm step : 6
Temperature : 38.71
Current : 49.6
Current filtered : 42.1
Voltage : 45.41
Duty : 0.890
RPM : 40390.1
Tacho : 57013
Cycles running : 3141
TIM duty : 4158
TIM val samp : 2080
TIM current samp : 4417
TIM top : 4674
Comm step : 1
Temperature : 38.56
It seems, that limit is 50A for Motor curr max.
When I use 40A, it is OK without issue, when I setup 50A, issue is there. No matter what is setup for battery (40 or 50A).
Test was done without load, just on deck…
I will try it on full load tomorrow…
DRV error is reported by DRV either something is bad with mosfets cant turn on mosfets or internal temp is high of drv or etc stuff mostly is blown drv…
As you can see, temperature is OK. And it is weird that two units have the same problem… Fault : FAULT_CODE_DRV
Current : 49.6
Voltage : 45.41
Duty : 0.890
RPM : 40390.1
Tacho : 57013
TIM duty : 4158
TIM val samp : 2080
TIM top : 4674
Comm step : 1
Temperature : 38.56
This unit is new, used once for now…
Already send message to flipsky…
I just put the motor max at 35-37 and am satisfied with fewer cutouts. I also added in -15 throttle expo for a softer response and seems to help. Basically if you want less issues go to the vesc 6 series. Good luck to you.
Isn’t there a limit with the VESC with 40000 RPM? Don’t know if this is what applies here, but your logs show that it’s around 40k that you have this fault.
Are your motors really meant to spin that fast?
Limit in VESC 4.12 is 60000 eRPM.
I have 190kv on 12S, so this limit is hit with fully battery. But I have setup limit in VESC as max 60000 with 80% hit. So, it should be OK. Because I can speed for max without problem.
Probelm is with torque, special for startup or full thortle from lower speed. When I need more Amper from motor (more than 40A) DRV fault is there.
I already apoke with guy from FlipSky and they have recommendation for 10S for this dual 4.12. But spec is max 60V and 50-100A.
I will send result from this issue …
I am on 10s but still have the same issue. I have thought about going lower in gearing, but the drv code I reported at the beginning of this topic doesn’t report any under voltage or over current so I am not sure that would help anything. My belief is this thing is just cheap and wimpy and was not meant to do what we expect it to do and most likely does nowhere near the amp rating stated. Much like cheap auto amplifier/stereo brands advertise higher watts than they really are. Overall, it’s a great affordable vesc to get the job done, but not for performance.
I already spoke with flipsky and they recommend 10S for this dual 4.12. But, I use 12S.
I did lowering setup for Motor Curr max as for 40A only, so far good for me, without issue, but torque is missing there. So, discussed with them about refund, they offer me dual vesc 6.6 for half price as around 150$, so think about it…
