Fault_Code_Under_Voltage
0v from the xt is a main connection issue. Be very careful because you may have a broken main wire. Literally just had the same issue on an enertion pack that I was trying to use. Solder tab (paper thin nickel) had broken off in the shrink wrap and caused some nasty stuff.
