Feather | Agacê Cruiser | Kegels | 5055 DD | 11S1P
Well, as the name says the goal here is extreme lightweight and portable. Since my last build I realized that even if it’s a dream to ride, it’s a pain when you are not riding
This build at first will be just a resurrection of my old board with what I have laying around, but eventually it will be as the parts list bellow
Parts:
  • Agace Cruiser - 1800g
  • Paris 195mm - 860g
  • Kegels - 1008g
  • 5055 DD - 860g
  • 11S1P INR21700-40T - 737g
  • Dual VESC 4.12 + misc eletronics ~ 150g
  • 3D printed enclosure - 200g
  • fasteners, bearings, etc - 100g
Total of 5.7 kg, would like to keep it under 5 kg but it doesn’t seen possible
For now what I’m doing is evaluating if it’s viable to convert the 5055 motors to direct drive performance and heat wise, first step was to model them as it is, and them play with the windings, this is it wound as 190Kv runing at 40A
We can easily see why they overheated in my build, at 40A we are looking at 100w of heat loss
Take all this data with caution, I’m merely using it as comparison tool, not absolute performance
Checking if it will fit, I may change to 180mm Paris if it do
why DD? Wouldn’t it be better to go 42XX route with low gearing in order to make the most out of your battery?
I only would consider Hubs/DD if I had enough amps.
I recon that the deck weight quite a bit too, I would try shaving some grams there.
Probably, but I want to test a DD before going forward with the large DD design for my big board
I’m still on the fence if the 5055 will be enough
The main misconception with hubs/DD is that the Kv matter, it doesn’t, it only affect the current needed from the ESC and battery, that’s why people overheat their hubs, Raptor being the main example, pushing more current in a low Kv motor will only make it heat more and more
Example of the 5055’s, if I take it as it is, 190Kv and just bolt to my wheel I will have the same torque for the same loses, now if I want more torque to overcome the lack of gearing them I will push more current and it will heat up a lot
The truth is that there is no replacement for bigger motor/more cooper
Just as an experiment I scaled the 5055 up to the size of 6355, keeping same Kv, now I can produce the same torque at half the losses
:wink:
Could you go a little further? each time I think I got how everything comes togheter there is something that throws me off, we got flux and current that generates torque, whats p? the radius of the airgap?
p = pole pairs. my only point is that by having a 1:1 gear ratio yo need so much more startup current than a geared system. Therefore you generate I^2 more ohmic losses
compared to a 1:3 gear ratio 3^2=9 times more losses =! heat + poor consumption
Thanks
Yeah, that’s the problem, the only way to overcome that is keeping the same ampere-turn relation, my 190Kv motor could do 40A, rewound to 60Kv it can do 12.6A for the same heat loss But as you said the problem stats when you expect the same torque for the same motor ungeared, the loses go through the roof fast
As a test I did some calculations and adjusted my board to have the same torque as the DD would have at 2 N.m per wheel, to be honest it’s not great obviously, but it gets the job done, the low speed performance sucks a lot, probably due to the low efficiency of the motors at that range, but once you get to higher speeds is handles well
I refined the simulations a bit and it seen I can get 2.5 N.m for each wheel while keeping heat loss reasonable, I may even at first go without rewinding the motors, it will put more strain on the VESC for sure
Another goal of this build is investigate the effect of Statorade (https://www.ebikes.ca/product-info/statorade.html) on a DD setup, Justin from Ebikes.ca did some tests with Jacob and Inboard hubs, but the effect is not that great because we have the polyurethane in the way
For my big DD in the works I plan to go that way, it makes way more sense to extract heat from the stator that way instead of trying to get it through the hanger, the surface area that could be available from the bell is way bigger
1300 rpm = 20 km/h 2000 rpm = 30 km/h
For [email protected]@40A:
For [email protected]@10.5A:
If rewind happen, the Kv will have to be increased a bit to have peak efficiency at 25 km/h, which is the speed I plan to limite this build
DD design done, pretty simple to keep costs down if this should go wrong, also Dexter confirmed that the magnets are N42SH, so I will be able to to run them hotter = more torque
Also I did some thermal simulations, running them at 20A the core will get up to 100°C while the magnets should not go ove 80°C, all this considering the loading they are subject in a typical ride for me, also the software allows me to use oil on the air gap simulating the Statorade, them the everything stay bellow 90°C even at higher currents, with a total of 9 N.m at the wheels
Another concern is that I am almost sure the hanger will bend, but it’s cheaper than making one from scratch for testing image
Test fit, still have to find a suitable capacitor, fit the arduino and an NRF module and if possible a charge only BMS, I may skip it if I can find a 13 pin circular connector that’s not huge
Why 13 pin? Wouldn’t 12 pin suffice for 11s?
Actually, ideally it should be 14 pins (or 13,depending on them BMS), 12 for the balance wires and positive and negative, if you use b1- and b11+ to actually send current into the battery there is a considerable voltage drop in them, so the BMS/balance charge would first balance considering this voltage drop and then has to balance again as the current drops
My first board was like this, two 5S balance connectors to charge, the current would flow by the same wires the battery voltage is measured
There are some nice and cheap connector from the GX20 series that have up to 15 pins
True. I have exactly that problem in my setup. I have the balancing disabled on the BMS and use it only to monitor the cell voltages and to cut the charger once any cell reaches 4.25V. The first cells to reach that reading are always the first or the last cell because of the voltage drop. In reality they are around 4.15V, which is where I want to stop charging anyway. The 4.25V is still a safe threshold should cells get out of balance.
I agree it’s not ideal though. I would prefer extra pins for charging. I currently use a 12 pin connector for 10S battery pack so I’m missing one pin.
Also with 11S1P you probably can’t really afford not to charge to full.
You described it perfectly
I’m still thinking about 11S, it’s harder to find chargers and BMS, buyout gives me more range, 12S in the flipsky is risky, even more since in 11S the spike during regen is greater
I may even got 7S2P of 30Q, it would weight 672g vs 737g for the 40T, be cheaper while keeping the same energy but with probably bigger interl resistance
Maybe 8S2P would be better? 8S balance chargers can still be had for cheap.
Could it be, most times I will bulk charge
And thinking about, the 12 pins you suggested can work, I don’t need to balance it, just have access to each cell to measure and if out of balance, charge each P group individually
If you go that route, you might find my external BMS charger handy. It’s based on the LLT Power Smart BMS. I described above how I use it. No balancing. Just monitor and stop charging at the right time. I added a little display, which I control with Arduino NodeMCU. The Arduino NodeMCU gets cell voltage readings from the BMS and adjusts the first and last cell since it knows how much voltage drop there is on the charge wires, so it always shows the correct voltage on the display even while charging.
Thanks, will take a look
Doing a little comparison between 11S1P of INR21700-40T and 7S2P of INR18650-30Q
Main advantage of 30Q is that I can source them locally and for a really good price
                                11S1P/40T                      7S2P/30Q
Weight 737 g 642 g Max [email protected]: 1424 W 777 W Pack IR: 0.22 Ω 0.14 Ω P. Loss @300 W: 12 W 19 W Energy: 157 Wh 150 Wh Cost (BRL): R$496,00 R$378,00
(EDIT: apparently I don’t know how to make a table here)
40T wins easily while not being a lot more expensive, just have to find someone that ships it here If the 30Q would be capable of a bit more power they would really be great, I will be able to get approximately 500~600W from the motors, maybe running them at 20A like a lot of people do
I don’t know where you get your pricing from but even at 1/3 better stats the price of the 40T costs more than 33% more. Meaning the only reason you would pick it over the 30q is if your enclosure for some reason fits 21700 better than 18650.
