I´m building a 10S Setup at the moment with 2x 5S Turnigy Lipos. To avoid deep discharge i ordered two of these lipo warners, one for each battery.
Now i´m asking myself if i also could use just 1 beeper for both (serial wired) batterys using my parallel balancer adapter which i use to charge my batterys parallel? This would make the charging process a bit quicker because i could let the parallel adaptor plugged at the balancer plugs of the batterys all the time. Also the cells of the batterys would balance themselves automatically when they are connected through the balancer ports.
I´m also curious how much the lipo warner(s) will drain the batterys and if one should unplug them while not riding for a few hours.
EDIT: After sketching the circuit like a 5 year old, i realised that plugging the balancers parallel in a serial setup will cause baaad shorts So no good idea.
