How do you guys fill in old screw holes(In your deck) from your enclosure?
do you mean holes in the board? i used hot glue, it’s not pretty but keep water out
I have not tried filling in gaps but maybe something like Wood filler, No more gaps, Liquid nails.
Yah holes in the deck, from the old enclosure screws.
-put tape over one side of the hole. -flip the deck, -fill the hole 4/5 way up with baking soda. -slowly add in drops of superglue. It will dry rock solid. -repeat until the hole is filled
Thanks! 10 char
Epoxy worked for me
If your trying to reuse a stripped hole mix sawdust and wood glue into a paste. Pack the hole let dry. Then predrill the new hole. Works on old doors.
