First you need to decide your budget.
Do you want an “SUV” with spring trucks or something more like evolve?
168kv is a lot of torque, you can probably go higher if you want more speed instead.
For your desired range you’ll probably need a 10s4p, maybe 5p.
Definitely get a vesc! There’s plenty of different ones to choose from.
If you specifically want 12s I’d recommend the FOCbox or a decent vesc 6 variant. Flipsky’s mini 4.20 is also supposed to be able to handle 12s without any trouble but it’s still unproven for that on a mass production scale. It can definitely handle 10s though.
Those trucks look fine if a bit on the heavy side. Having off-road tires on the rear and streets in the front could be good for overall use- more traction in the back and grippier steering in the front- but I don’t actually know.
Quick advice for those trucks, they work great but the mounts have a few flaws. First off, get a steel beam and bolt it to the bottom of the motor mounts, they flex under torque and this prevents them being pulled towards the wheel. Second, if you can make bar going across the top side of the mount do that. I had one mounts break at the 90° angle. I should have seen it coming and added a filet weld in there to strengthen it.
