The “little wires” are for balancing and yes, they are connected between each p-pack (as in the SuPower wiring diagram). The 10th one on the battery positive.
If you by xt90 mean an xt90s anti spark plug, that’s connected on either the positive or the negative battery wire going to the vesc as seen in the diagram.
pssst I wouldn’t even know how to set it up normally either… this is literally my first battery build… and im new to building… but I’ve learned a lot in a short time… i can make enclosures now and I’m learning batteries… I’ve already built a board and working on a another
Hey one more quick questions if thats cool… since im doing the bypass the gauge of the wire that is coming out of the B- terminal doesnt need to be 10awg correct? I can use smaller gauge wire to connect it to the negative wire?
The deck itself was $85 I think. I’m in Milwaukee, WI. Hey another quick question… the little positive wire that comes out of the bms that I have to solder to each positive group… so let’s say group 2 positive that is connected to group 3 that is negative… do I have to cover it up with kapton tape to prevent the solder end from positive group 2 from touching the negative end of group 3?
Not sure… $85 deck, $320 motor controllers, $250 motors, $40 on/off button, $60 remote, $250 battery, $200 motor mounts, $50 pulleys/belts, $10 enclosure, $175 wheels… $160 trucks… maybe $1650ish… I might not use the evolve trucks and motor mounts on this build and use them for another landyachtz evo build im going to make to sell… so might be able to knock off a few hundred… crazy how it all adds up so quick
